Hello there,
I've recently got a file format in RealMedia VBR (rmvb). Does anyone knows how to convert such file format to avi/mpg?
Thanks alot....
Please help to keep this thread alive and i think quite a number of us has such problems as well....thanks again
okie dokey... this worked for me... Download real media alternative from Kazaa lite website also download the codecs... then download TMPGEnc...
open the RMVB file into realtime alternative and then go to file and then save and just save it... then go to TMPGEnc and open the saved file and then convert it... it's that simple i only found it out by trial and error.... -
Did Real Alternative save it to wav?
But real alterniata is no tool(only a codec)....exactly where did you convert the audio???...in media player classic that is included?
How do I know if file is CBR or VBR?
By mst in forum Newbie / General discussionsReplies: 15Last Post: 6th Dec 2020, 20:14 -
VBR (Variable Bitrate) WMV file to avi conversion process problem...
By Atakanbasturk in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2009, 17:44 -
How to play and convert the RealMedia VBR?
By coody in forum Software PlayingReplies: 6Last Post: 29th Sep 2008, 20:33 -
what is the difference between VBR and CBR of a mp3 file?
By sumeshkri in forum AudioReplies: 3Last Post: 19th Sep 2008, 08:31 -
CBR vs VBR with same file size.
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 18th Jun 2007, 02:47
