is it ok for the .bup file in a dvd to be missing because, after i ripped it in smartripper i didn't get a file, so im just burning the files that i was provided with...holla back..im kinda new to this
Results 1 to 30 of 31
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Na im sure he have to have it.The .bup file is a backup of the .ifo file.
Big 3 User.....
PAL User....... -
@ sircooks, as Haku said ..the.... .bup files are backups of the .ifo files of their respective vob set. They are there in case of damage due to scratches, etc. Standalones detect the structure of the DVD and if that .bup file isn't there...then it's not a fully complaint DVD and may not play. If you can't rip that .bup, your best bet is to just recreate an entirely new set of files. IFOedit should create a new set of fully compliant files.
cool..i just wasted a dvd-r then...ill be more patient next time
bup's are just backup's of ifo's. Just copy the corrisponding ifo to another folder, change the extension from .ifo to .bup, and copy it back.
Ex. You have VTS_01.ifo but not VTS_01.bup.
Copy VTS_01.ifo to another folder, change the extension to VTS_01.bup, and copy it back to the original folder.
PS: Who's the delicious porno quality babe?I don't have a bad attitude...
Life has a bad attitude! -
now that sounds like a better idea...i will do that now...so smart ripper isn't the best ripper...is this dvdfab really worth it....holla back
ohh, the babe just happens to be a rapper named "Trina" who i think is the finest chick in the world next to my girlfriend...ps...dont tell her that...........
Yea, they are, but are you sure there is no code within the files that specify one is a .BUP file and one is a .IFO file?bup's are just backup's of ifo's. Just copy the corrisponding ifo to another folder, change the extension from .ifo to .bup, and copy it back.
Even though they are identical..there may be something internally that specifies one is the backup. I also believe that .BUP stands for 'BACKUP.' At least that would make sense. Even though it's a backup....internally, the .BUP file may indicate it is exactly that...the reserve/backup file. So changing the extension might be a problem. Have you changed the extension of an .IFO to a .BUP before and tested it? It seems like that would work..but if there is anything that specifices backup from original internally..then there may be a problem. If you aren't 100% certain then IFOedit is the best option. -
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Originally Posted by defense
Yes, I've done it b4.I don't have a bad attitude...
I thought you were not interested....Originally Posted by leeboYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
cool, i'll take your word for it..and should I ever be without a .bup file, I will have an instant quick fix.Yes, I've done it b4.
once in a decade.....Originally Posted by defense
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
..... lol... I was thinking like once every century...especially with as heavy as a scrutinize things...but hey....if I live another 100 years, i'll have to have a quick fix...ya know? Yea, i'm sure the technology will be ancient as the DODO bird by then...but hey...at least I'll have a quick fix for my ancient DVD's. Oh, but then amnesia at that age...crap..I better write this down and keep it in my wallet.once in a decade
Seriously though..when the forum search feature is fixed and another forum memeber has the same issue...they'll see the post and find various ways to rectify the issue....the quickest being Leebo's method. Good lil' trick. -
Originally Posted by tompika
Please direct me to my post stating that I wasn't interested in porno quality babes.I don't have a bad attitude...
no statement, I just got that feeling....Originally Posted by leebo
Lesson for today, grasshopper:
Impressions based on Internet communications not to be trusted.
Actually, I've been mistaken for being a member of, shall we say, the "angular joint persuasion ", once or twice in my life.
Thats fine. Just don't leave me alone with your teenage daughter.I don't have a bad attitude...
just to let eberyone know, that leebo said if your missing an .bup file and that copying it and renaming it will do the same thing, in my experiences just recently he is wrong, it didn't work for me, i did find out how to use dvdfab, and that gave me what i needed, so if your ever mising anytrhing for a dvd, try dvdfab , like ton the tiger says....ITS GGGGRRREEEAAATTTT..........LOL..peace out
You are welcomeOriginally Posted by SIRCOOKS
How did it not work for you? Did you get a playback error on your player? And if so, how do you know that it was because of the .BUP? I do not think the player will even use the .BUP unless it is unable to get the information it needs from the .ifo, so I kinda doubt its the .bup that is your problem.
As far as I can tell, there is no difference between the two files except the file ext. If you rename .BUP to IFO and open it in IFOEdit they are the same, so doing the reverse shouls work fine too. I have done this many times with no problems. I think Leebo is right. -
I got a 3 yrs old son.Originally Posted by leebo
But I won't leave him alone with you, just in case ...
I have made DVDs without BUPs and they work.
If the player firmware is lazy, it won't look unless it
needs it. -
hummm...maybe it works in some instances, maybe not in others. Some players as mentioned, will play the disk without that file..others won't. Could be your player too.just to let eberyone know, that leebo said if your missing an .bup file and that copying it and renaming it will do the same thing, in my experiences just recently he is wrong, it didn't work for me,
IF it were the .BUP file...then just because the files are the same "size" and report the same info...maybe something within the file specifies backup and original between the two. That's my guess....either way....glad to see it worked out for you with DVDFAB. -
As I said, I've done it before.
Changed an ifo into a bup, that is.
Haven't developed any creepy feelings for 3 year olds though.
tompika, you are very blessed. Though at this point in my life I'd prefer the porno babe.I don't have a bad attitude...
If you have any file comparision software that can compare binary (like Arasix Merge) compare the .BUF and the .IFO file, they are identical.
So, All you have to do is copy the .IFO and then rename it to .BUF, it'll work. I've done it many times
-A4 -
All right, all right.
I was just teasing you.
however
How do you like your new transparent spidey?
Even mo' betta! (Whats the little dot down in the bottom left corner though?).
So you have the whole thing. I think I had cut it down because it surpassed the size limit for avitars on this site.
I anxiously await your next edit - possibly a chorus line of spideys?I don't have a bad attitude...
this one?
What dot....your screen is dirty!Originally Posted by leebo
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 03:06 -
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 12:14 -
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 12:26 -
How to merge/combine and/or convert VOB, BUP, and IFO into one file?
By gordes04 in forum Video ConversionReplies: 3Last Post: 11th Apr 2010, 20:39 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 08:47
