Results 1 to 16 of 16
  1. Illegal floating decimal point calculation order:; shows up
    during convertion from .avi to .mpg with TMPGen v.12i...
    Questionid I do something wrong or is the file just corrupt.....??
    .avi file works 100%!!
    PLZ some assistance would be nice THX
    /////Woody
  2. I get that with corrupt DiVX files. Run the DivFix program to see if there are any errors, then frun the avidefreeze app to fix them if there are. After that TMPGEnc should work fine...
  3. Ya, i have a divx file just like that, and TMPG freaks out with the same error at a point in the movie where an explosion occurs, and the screen goes completely white. I ran it thru VDub, tossed in a very small contrast filter, no more problems.
  4. Nope.............
    I ran the .avi through divx-fix...nema problema.
    Tried to convert with TMPG again but it halts at the same spot as before
    Then I separated the video and the audio with virtualDub
    and tried to remerge them into one .mpeg file.....But NOOOOOOO..
    and to Gryphin..It is not very bright or dark or anything
    special with the frame that halts TMPG....
    THX anyway
    /////Woody
  5. ive had that before. are you using 12a? goto that spot in the movie, and you will find some error. try re-downloading.
  6. Nope IŽm using 12i.
    IŽm sure that it is an error somewhere but divx-fix canŽt
    find it for me,,,,so ?????
    Last thing I tried was to re-derive the keyframe flags with virtualDub..But there were errors
    Re-DL is an option but it takes sooooooo long....
    /////Woody
  7. Last time I had this problem, I used vdub to re-save the avi using a different codec. Well, I only used a different codec because I wanted as little re-compression as possible to save quality and to give myself some assurance that it was really being converted so the error would go away. It worked. I've got another one I need to do this with as well, as soon as I get around to it. Though I'm going to see if tmpgenc 2.0 still has the problem first.
  8. Wouldn't it work to frameserve from V-DUB to TMPGenc?
    I've come around some problems I had with movies that way, but I haven't tried for illegal floating point problems.
    I have 1 movie with that problem, will try when I get back home.
  9. OK..more bad news..
    I re-DLŽed the movie and it is still the same problem at the exact same spot so I donŽt think it has something Ž
    to do with coruption during DL...
    IŽll try to resave the .avi and see what happens..
    /////Woody
    Sep 2001
    Australia
    i get that same error except it is right at the start of when i try to encode a MOV file, i have the QTReader and all my other .MOVs are fine. just this one
  11. No good trying to resave the .avi file
    (Unexpected error -100)????????????????????????
    Any more good ideas?
    /////Woody
  12. why try to fix the problem when you can go around it !
    I had the same prob and all I did was to note the frame-number where TMPG stopped.
    Then I encoded up to a few frames before the bad one.
    Then I encoded from a few frames after the bad one.
    You loose approx 10frames - half a sec.
    Youll end up with 2 mpgs but they can of course be joined.
    brgds
  13. Thx for the tip..but..!
    how do I ,With TMPGen. decode to a specific frameŽ,
    and after that from a specific frame?
    to get around the problem so to speak
    /////Woody
  14. under setting, choose advanced,
    double click on source range and there you go
    hi from denmark
  15. Will try that......
    thx from sweden
    /////Woody
  16. do the easy way, which took me less than 2 mins
    use virtual dub, open the movies, ignore the error it tells ya.., since it detec the bad frame...
    now just head to the frame number, or use the slider..just press the DELETE key on the bad frame..
    now save the avi- using direct video /audio stream..voila
