I'm not a newbie, but I figured this would be the correct forum to ask this. What exactly is the audio/video interleaving in vdub actually do? I'm not talking about the audio skewing option, I know what that does. I'm talking about the box where you can enable/disable interleaving. The defaults are preload 500ms of audio before video starts and interleave audio every 1 frame.
Should this option be enabled when frameserving or saving an edited avi? Like I said, I'm sure what this does or what effect it has. Maybe it's used by DVD players to pre load audio?
A/V interleaving does what the name suggests -- interleave video and audio together, very much like a multiplexer with MPEG1/2.
Let's say you have a AVI clip, which you want change its audio with a new audio track. You load your clip in VDub, choose Audio --> Wav (MP3) in direct stream mode, enter your configuration in A/V Interleaving, like A/V delay to maintian synch, save as new AVI. Now you have a new clip with new audio track. Most versions of VDub have problem dealing with MP3 audio. For that poupose, you might need NanDub.
Hope it helps.
Does the interleaving option in VirtualDub 1.9.11 handle 5.1 sound?
By WebMaximus in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2012, 07:43 -
De-interleaving?
By Xpenguin17 in forum EditingReplies: 7Last Post: 12th Jan 2011, 23:27 -
avi.NET sound problem in Interleaving AUDIO with VIDEO muxing
By ntiki in forum Video ConversionReplies: 4Last Post: 13th Mar 2010, 17:34 -
Audio interleaving? What is it?
By GangstaRap in forum Newbie / General discussionsReplies: 10Last Post: 25th Jan 2008, 02:43 -
how to use audio interleaving in virtualdub?
By sharmine in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2007, 03:00
