I've just tried to extract the audio from a movie, i select full processing mode under audio tab, then click save wav, and i get the above error messgae. The audio is in AC3.
Can anyone help please?
I can save as a direct stream no problem, but i'm wondering if i will lose sound quality?!?
AC3 codec is installed and works fine!
thanks in advance
/TheDJ®
Results 1 to 10 of 10
thx for the reply.
So is the AC3 causing this problem??
I have done divx 2 dvd before with ac3, and works fine by doing full processing mode.
Dont quite understand wot the problem is.
I'm afraid i am not experienced in using the software u have mentioned.
I've just checked the file information of the movie in VD, and under audio compression it states: unknown (tag2000)
That "unknown" audio codec and the warning about not having an audio decompressor is what I've seen every time I've opened an AVI file with AC3 audio. I always just did the direct stream copy and converted to WAV (or directly to MP2) with besweet.
A man without a woman is like a statue without pigeons. -
When i extract the wav using direct stream, i find the size of the wav is much smaller compared to full processing.
Wot i did in the end was, used avi2vcd program to decompress the movie file, then i was able to extract the wav in VD by using full processing mode, the movie is now converting.
The wav size was 1.4gig.
/TheDJ®
Goldwave will extract AC3 sound from avi's to wav format. Here's a guide.
"Art is making something out of nothing and selling it." - Frank Zappa -
That's because it's not a WAV when you do that, VirtualDub just insists on naming it .wav. It's really an AC3 file. If you have a file with MP3 audio and you use "direct stream copy" you'll get an MP3 file named .wav.Originally Posted by TheDJ®A man without a woman is like a statue without pigeons.
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 04:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 16:36 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59 -
"No audio decompressor could be found..." in VirtualDubMod?
By Bix in forum Video ConversionReplies: 5Last Post: 6th Sep 2007, 19:35 -
By Bix in forum Video ConversionReplies: 2Last Post: 6th Sep 2007, 16:18
