when i try to convert my avi file to mpg using tmpgenc... i try to load the avi file and it says cannot load avi formast file
-ganJa
You're probably missing a codec. Use GSpot to tell you what codecs the AVI uses.
You could also try to open the AVI in VirtualDub and frame serve it to TMPGEnc. I've found that VDub often has no prob opening an AVI that TPMGEnc refuses to open.
/Mats -
What are the details of your file ?
mpg to DV-AVI converters
By nuttyDeedee in forum Video ConversionReplies: 7Last Post: 31st May 2009, 17:13 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
MPG clips to AVI
By Marcel555 in forum Video ConversionReplies: 2Last Post: 2nd Nov 2007, 17:07 -
avi to mpg
By zoranb in forum Video ConversionReplies: 7Last Post: 12th Sep 2007, 15:09 -
flv to avi or mpg
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2007, 02:25
