Its a matter of efficiency, I dont have the time to sit and watch through the entire video and make notes. I work primarily with music video and I need to be able to drag the pointer close to the end of a song, then hit play to note the exact end point to add a chapter. Without being able to monitor the audio its a pain, and while your idea would work, its an extra, time consuming step that should be completely unnecessary.Originally Posted by housepig
DVDlab also allows you to adjust audio timing for those files where audio and video are slightly out of sync, doesnt this seem like an odd feature to offer if you cant monitor the audio to determine how much of a change +/- to give the audio track to sync up to the video? Sure, you could do this in another application too, but that would likely be a dvd authoring app, again making dvd lab pointless.
Mind you, my frustration is because if DVD lab could monitor audio, it would be THE tool. I'm not just trying to rag on it, I just wish I could use it.
-v20
Results 31 to 32 of 32
"Did you see what GOD just did to us??" - Fear and Loathing in Las Vegas
I am amazed at the complexity to create DVD with AC3 audio. neoDVD Plus is a cheap program that can encoded AVI to DVD with AC3 audio (no sweat).
Yes, I know many do not like the canned menus and other restrictions. For video thjat are not too long (~ 90min or so), neoDVD Plus does a very nice job VERY QUICKLY.
How about ReelDVD ? You drag in .WAV or MP2 file and it will convert to AC3 automatically. The downside, ReelDVD is expensive.ktnwin - PATIENCE
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 05:42 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 08:52
