i have a vid on my comp (2 avi files which i joined), the joined avi files play perfectly, as i joined them with vdub mp3 freeze, when making the dvd mpg i used goldwave to extract the wav file and i used the "dv audio -- NTSC 48.000 KHZ 16 bit stereo, then i got the wav file, went into tmpgenc choosed CBR MPEG 1 LAYER 2 AUDIO (MP2) , to create my dvd file, went through all the motions and at the last page of tmpgenc chose to encode it at 6000, since if the file was to big, after i convert it in tmpgenc dvd author, i would have shrunk it in dvd2one......so after all of that i left it on over night to encode the movie....woke up to inspect the file to find that there is no sound in the middle of the movielike the first 30 min theres sound then theres silence for another half hour, then the end ing of the movie has sound.....WTF is up with that...holla back....if there anymore informationneeded just tell me............![]()
Results 1 to 9 of 9
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
nobody has a clue...this is only happening to me...........
look, i know someone can help me, i just encoded my vid with main concept mpeg encoder, and the picture is great, but still no sound, could this probably be a codec problem......unlike the ones i enc0ded in tmpgenc, the one in main concept, had no sound at all?............im baffled please help....if you need more help dony hesitate to pm me
AAAAARRRRGGGGHHH...........WHAT THE HELL AM I DOING WRONG............HELP MEEEEEEEE......
Load your joined file into vdub and drag the bar at the bottom until you get to the point where there is no sound in your TMPG file. You're using the original file here not the one created bt TMPG. Play it and see if you have sound. Let us know what's up.
k...will do...........
yes i do have sound in the middle of the original file when played in v-dub...whats next
sounds to me, without knowing anymore about the source file specs, like the avi audio is shorter than the video. Did you do a frame rate conversion (2 part question....is the audio and video the same length when they are split and is the avi the SAME frame rate as the final movie).
You might find it easier to do this conversion using dvd2svcd. It has an option in it to convert avi files to VCd,SVCD,CVD, and DVD. Try that and post back.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Big Problem
By k_pratl54 in forum DVD RippingReplies: 7Last Post: 9th Mar 2010, 21:37 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
mpg to DVD problem
By toughdiamond in forum Newbie / General discussionsReplies: 14Last Post: 21st Nov 2007, 07:17
