I got a problem. I use KVCD (704x576) templates to encode my videos and everytime i add it to dvd workshop it keeps reencoding my videos even though i click on 'do not convert compliant files'. how do you stop it from doing this. i have version 1.2
Not sure this'll help, but worth a try. Check your project preference settings before you set up the project. Make any changes there.
I've also read that you may need to un-tick and then re-tick the "do not convert...." box to get it to recognise it. -
From past experience the software does not like remembering past selections. Each time you click or change an option it resets the settings. So my advice is to keep checking everytime you change something.
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 23:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
