Ok, to get it over with I’m a newbie and I searched! :P
My problem is thus…..
I have PAL TV with a Pioneer DV-535 player. The player has a switch to change between NTSC, PAL or Auto. If I try to watch a NTSC DVD with the switch on PAL or NTSC it comes up in black and white. However when I have it set to Auto it is in colour. Can anyone explain why this is so?
My main question though relates to the quality of the picture when it is in colour. On the TV the image seems slightly pixelated like the picture is divided by a very fine grid. What is causing this and can it be overcome?
Thanks.
If set to auto, the player probably uses different frequence range for carrying the color signal than normally used for NTSCIf I try to watch a NTSC DVD with the switch on PAL or NTSC it comes up in black and white. However when I have it set to Auto it is in colour. Can anyone explain why this is so?
NTSC resolution is less than PAL resolution, so individual scanlines become more easily noticeable. I don't think there's much to do about it, except watching from a smaller TV.My main question though relates to the quality of the picture when it is in colour. On the TV the image seems slightly pixelated like the picture is divided by a very fine grid. What is causing this and can it be overcome?
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26
