  1. Member LisaB's Avatar
    How can I set things up so that when the last chapter of a movie is playing, and I hit the next button, it goes to the first chapter of another movie.
    This seems simple (and it's the default behavior on an SVCD, for example), but I have not figured out how to do it.
    Yes, I can draw a link from one movie to another -- but this just means when the one movie ends the next movie automatically begins playing (instead of returning to the menu, which is the default).
  2. You must use IfoEdit for this:
    First, you find out the PGC-number of your next movie,
    then you go to the first movie´s command table, go to the
    "next PGC number" and enter the nr. of your next movie there.
    If you´re not familiar with IfoEdit (it is NOT easy), then check my
    "IfoEdit for dummies" guide on my website here:
    http://home.arcor.de/josef.braunstein
    LotD
    for some info on DVD-programming visit my website:
