Hello...
I have several (actually about 120) .vob files that I need to convert just the video portion to 640x480 23.976 MPEG1 files.
I can extrace the video with bbDMUX which povides an .m2v file. I cannot seem to convert it using bbMPEG or Tmpgenc, the files will not open (errors when selecting the m2v file). I have WinDVD installed and it can play the files fine, I just can't convert them.
Any help would be appteciated.
Oldie
http://www.vcdhelp.com/mpeg2tovcd.htm
or use FlaskMPEG. -
Yes, I have tried the guides on this page and I can use the one mentioned above. What I need help in doing is setting up some kind of batch process or automated routine so I don't have to run through each file individually.
Opening them up directly would have been ok (without the dvd2avi step), because I can set up a job that converts them all. I can't, however, because they need some pre-processing.
Oldie -
what kind of preprocessing???..what does DVD2AVI say when you try to open them??..where did the vob files orginate from?
DVD2AVI opens the m2v files just fine. I can save the project, which creates the d2v file, and then open it in TMPEGinc, so no problem there.
I just don't want to do that manually 100+ times. Click - type - click - type - etc. Especially since DVD2AVI doesn't use the name of the opened video file when saving the project (the dialog is empty and must be typed in). I cannot combine the video files, they don't go together at all.
In the time since I've posted this, I probably COULD have done it all, it's just the thought of it that is keeping me from doing it.
Oldie
(Sound Problem) Converting karaoke Vob file to mpg/ other video type cause.
By kiangtong in forum Video ConversionReplies: 1Last Post: 23rd Jan 2010, 03:45 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 20:28 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Problem converting VOB to MPEG2 with mpeg2enc
By Massa in forum ffmpegX general discussionReplies: 3Last Post: 3rd Jan 2009, 06:51 -
any tool for converting vob files to mpeg1?
By sumeshkri in forum DVD RippingReplies: 8Last Post: 18th Feb 2008, 22:22
