  1. this is probably a really easy question. i set the extension .m2v to open with powerdvd. everytime i open a file with powerdvd it puts a file labeled Default.PLS in the folder where the m2v file is. how do i make it stop doing that?
  2. I get this too (PowerDVD will do this for any movie file you play). I read the online manual for PowerDVD and couldn't find the answer. I'll let you know if I find anything.
    Anyone else know?
  3. I've always assumed that was a playlist. I don't know how to stop it from being created all the time
  4. Banned
    Feb 2003
    Columbus, Ohio
    i try to explain this the best i can
    it's not powerdvd . it's windows
    in windows, there are lot of files and folders
    in each folder there is some kind of extension to open the file to make windows know what type of file it is
    like for instance
    if you click my pictures
    you will see pictures
    but if you go into folder options
    and check 'show hidden files and folders'
    and uncheck 'hide protected system operating files (not recommended)'
    you will see thumbs in the folder too
    that what windows use to operate that file
    the same thing happen when you view mpeg or vob in a folder
    i have power dvd but my files say musicmatch as the default pls when i open a vob file or mpeg file
    if you use power dvd to read the main ifo of the dvd instead of the vobs to watch that movie
    that pls icon won't come up
    it will come up for mpegs though
    p.s. make sure you delete that file before you burn your dvd video_ts folder as that can probably cause problems as for as your dvd playing in a standalone
  5. i read the other thread. what binary editor do i need to use to do that? like Visual C++ or something? whats teh easiest one to use?
