    Hamilton, NJ 08610
    I'm using premiere on a PC to export using the Adobe MPEG encoder. I set chapter markers within the timeline. I export to get a .m2v file as well as a .mpa audio file. I then move those files to my G4 MAC where my burner is. When I burn using "sizzle" it does not see the chapter stops. Any ideas?
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    I think premier's chapter marks are only for their own DVD mastering software whose name eludes me at the moment. To make chapters with Sizzle, you have to set the times for each chapter break in the chapters tab. I haven't tried 0.5 yet, so I don't know if that changed since 0.1, but in 0.1, you just listed the points in the timeline where you want the chapter breaks, i.e. 00:05:00;00:10:00 . . . I think that's how it went. I can't check right now, as I'm at work, but there are other threads in this forum that describe chaptering with Sizzle with more detail.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
