Hey All,
To backup my movies I use a HP300i DVD+R drive and use Memorex 4.7 GB DVD+R Media discs. My PC is a P4 200 mhz 40 gb system and have backed up close to 20 movies in my collection so far. I recently purchased Head of State and was playing around with the multiple sound tracks and have run into a problem.
To back up my movies, I use DVD Decrypter file mode, copy all to the hard drive. Then i use dvd2one and do full disc but only choose one soundtrack. I use Nero to burn and all has been well since using the guides on here. For some reason head of state comes out to a size of 4.37 gb which is 100% correct. But when i go to burn it in Nero it says the files are too large for the discs. Can that be the case? I tried Record Now MAX and the same problem occurred. How can Nero and RecordNow Max see it as a larger folder then windows?
Anyone who could help would be muchly appreciated...Thanks again,
Craig
Results 1 to 12 of 12
I think you mean 2000 mhz...if your computer is a P4. As far as your problem....it does sound like your files are too large. Try to burn onto a different type of media...like another brand and see what happens.My PC is a P4 200 mhz
4.37 is pretty much the max you can safely put onto a DVDR. And in many cases, that size is too big to avoid complications. When you right click on the folder what are your total BYTES. I have a feeling that you are closer to 4.38 GB's then 4.37. I've burned 4.37 GB's a couple of times...but I usually keep it 4.36 or less. -
Hey There,
The total byte size is 4,702,267,392. Im just curious as to why this disc is causing the problem and why i havent had problems up until this point. Do you have any recommendations? Any other shrinking software you feel produces a great image while keeping extras. I only want the dts soundtrack for this backup as well.
Thanks again -
You use DVD+R. Here's your problem
Blank DVD+R 4,483MB 4,700,372,992 bytes or 4.377GBOriginally Posted by cgiesler83
Blank DVD-R 4,489MB 4,706,074,624 bytes or 4.383GBYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Do not how this could relate but here it goes. I backup XFiles Season 7 Disc 2 using DVD2One 4472 default size. I tried burning with Nero using "ISO/UDF 1.02", it told me my files where to big. I Then tried it on the old reliable setting of "DVD-Video" selection. It burned it without a hitch.
I have switched to UDF 1.02 cause my iBook's Apple DVD player 3.0 will not recognize any DVD burn as "DVD-Video" only UDF 1.02 -
I'll have to look when I get home. I haven't updated to the newest vesion so I cant choose variable, but I read somewhere here constant is best.Originally Posted by cgiesler83
I'm thinking I set mine to 4450, just off the top of my head. Default I think is set to 4470 -
@ cgiesler83, just as I figured.....you exceeded the file size of the media. As tompika said..use a DVD-R and you should be fine. Keep in mind though..exceeding 4.37 GB's on either format isn't reccomended and you should be very cautious with burning that close to the edge on any media.
For future projects, I suggest you keep the total output to 4.36 GB's or less..and you'll put yourself in a better situation...but even then you can experience issues...just not as many. -
Unfortunately he can't.Originally Posted by defense
The HP300 is a plus only burner.
I meant he could shave a couple of MB off.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Yea, and he even specified that in his first post. I get too caught up with My Sony and think all drives are multi-format. I don't know what i'd do with a single format drive. Not only is it amazing for the erray of both formats...but when there's a sale...I could care less which format it is on sale...just grab one or the other.Unfortunately he can't.
Anyway, they are using Ricoh media, ...luckily for them they don't have a -R burner and have Memorex media..then it would be CMC and they'd almost certainly have a playback issue at that forced capacity. With Ricoh they should be ok...but still shouldn't force the max like that.
VHS-C black/white streaks possible video head problems.
By MadMax_911 in forum Capturing and VCRReplies: 20Last Post: 26th Dec 2015, 21:09 -
Woman died from being in a state of arousal.
By stiltman in forum Off topicReplies: 4Last Post: 12th Jul 2010, 13:21 -
Are Solid State Drives Better?
By Gromit137 in forum ComputerReplies: 19Last Post: 2nd Jan 2010, 23:11 -
Hi8 tape playback problems after head servicing
By pkn25 in forum RestorationReplies: 6Last Post: 26th Nov 2009, 10:52 -
Seeking State-By-State List of DTV Stations with Sub-Channels
By Frank-0-Video in forum DVB / IPTVReplies: 2Last Post: 2nd Feb 2009, 17:07
