Normally, I use TMPGEnc DVD Author to create my dvd's but it is so inflexible when it comes to laying out the menu, that I have turned to DVDit PE.
I have read several posts on here regarding creating menus. I size them to 720x576 (PAL), I save them as either a BMP or JPG, and then import them into DVDit and I make sure anti-aliasing is turned off.
They look totally fine in the softwear preview. But I can spend hours in Photoshop creating professional looking backgrounds, only to have them look incredibly crappy (excuse the language) in the final video once the DVD has been built. I have gone through what little settings DVDIT PE has, and there is nothing there relating to quality of the menu
Is there a reason why DVDit PE reduces the background menu quality like this, because TMPGEnc DVD Author certainly doesnt do it. Even if I use a BMP it comes out looking like a badly compressed JPG in the final video.
Alternatively, is there a better piece of dbd authoring softwear out there that allows you to drag and drop menu items to where you want them, but does not interfere with the quality of what you put into it.
Results 1 to 1 of 1
Proplem with mapping menu and title buttons using DVDit PRO 6
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 14th Apr 2010, 17:56 -
How to convert a video without wasting file size and reducing quality?
By tendra in forum Video ConversionReplies: 2Last Post: 29th Oct 2009, 07:24 -
4:3 to 16:9 without reducing quality
By trickytree in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jun 2009, 19:06 -
All-in-one program for multiple avis to dvd with menu and good quality?
By Yaeli in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2008, 16:01 -
poor DVDStyler menu quality
By bennyboy371 in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2007, 07:39
