I am using the SOny DRU 500A with the original firmware and currently use the DVD-PRO DVD-R's from Meritline. I know that they don't burn at 4X and am looking for DVD-R's that will actually burn at 4X. I haven't updated the firmware because, to be honest, I don't know how to disable the DMA settings on XP.
I am also trying to keep the cost under $2. I have been looking at the Ritek G04, Optodisc and BeAll's but am willing to try another brand if they will burn at 4X actual speed.
Thanks in advance.
SOYLENT GREEN IS PEOPLE!!!!!
I've only tried the 2 that came in my 4X media sampler from Meritline, but so far the Ritek G04's seem to work great in the DRU500A w/2.0f firmware -- better than any other -R media I've tried, and maybe even a little better than the 4X RICOHJPN +R's that have been so common lately. I'm thinking of buying a bunch more.
I have used about 300 silver top cheap Ritek 4x DVD-R without a single bad disc. Also I have burned TDK DVD+R and DVD-R 4x. The only media I have had problems with is Verbatim 4x DVD+R and Apple 4x DVD-R.
The 4X dvd-r's from meritline work fine in my burner with the updated firmware.
Can anyone give me details on how to turn off DMA settings on XP so that I can update the firmware? On the instructions on teh update page it says taht if you do it wrong, you can turn the DVD burner into a useless piece of metal.
Also, has anyone tried the Princo 4X?SOYLENT GREEN IS PEOPLE!!!!! -
You disable DMA in windows device manager. I have been burning Princo 4x printable DVD-R in my Sony DRU500ax at 4x speed without any problems.Originally Posted by godhead7a
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
