I would like to compile a dvd made up of specific chapters of various other DVDs and would like to know if this is possible. Which software would you recommend I use to do this if it is possible, and would there be any quality loss? I have authoring software which I would like to use for menus and so on also. Any help would be appreciated.
Regards
yea, you can do that, but the info you gave it too vague. Are you trying to make some type of highlight reel or something? AS far as whether their will be a quality loss..it depends how much data you are trying to fit onto the DVDR. Basically, the total of all the comprised chapters plus any extras and menu's will determine whether or not you'll have a quality loss.
You said you have authoring programs. Which authoring proggy's do you have?
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Ripping 50 DVD chapters to individual files
By indijay in forum DVD RippingReplies: 2Last Post: 16th May 2010, 02:05 -
Ripping DVD Chapters
By wallywalters in forum Video ConversionReplies: 1Last Post: 9th Feb 2010, 12:58 -
AviSynth - Add specific Chapters timecodes to your script
By imager in forum EditingReplies: 2Last Post: 26th Dec 2009, 07:25 -
Revert to Main Menu at ends of specific chapters in DVD Architect
By c627627 in forum Authoring (DVD)Replies: 5Last Post: 13th Jan 2008, 17:01
