I have been thinking about buying a Panasonic E30. I have an extensive Boxing collection on video that I want to preserve. I orginally bought a Terapin unit and have been very disappointed with it's performance.
I have heard the the DVD recorders perform very well....but I am very worried about the different formats. I know that the E30 uses DVD-R discs.
I have heard that the industry has not decieded on DVD-R or DVD+R.
I do not want to get stuck like Beta owners did in the 80's....I don't want to pick the wrong one. I also don't want to end up having to later convert from one to the other.
Any ideas on which format will stay and which will go. Any info given will really help me out. There may even be a machine that does both....but I'm on a limited budget, so the E30 looks like it would fit my needs.
You don't have to worry much about format wars between + and - as both formats are playable on 85-90% of existing DVD players. Once the discs have been finalized, + and - are pretty much the same. It's not like Beta vs. VHS were you had 2 incompatible tapes that would not play on the other machine. So even if one format were to disappear off the face of the earth, you'd still be able to play all of your discs on the majority of DVD players.
I'm sure any DVD will look better than the Terapin, unless you try to put 6-8 hours on 1 disc.
BTW - I still have 2 Beta VCR's and a Beta camcorder (ha!) -
I know somebody that has Beta tapes to
convert, and no player.
I don't suppose anybody wants to sell a Beta Player
for cheap ? -
I'm keeping both of mine for the time being, I have about 100 tapes to copy yet. You might try the Betamax group on Yahoo:I don't suppose anybody wants to sell a Beta Player
for cheap ?
http://groups.yahoo.com/group/betamax
I suppose I could copy Beta tapes to DVD-R(W) for somebody, but I'd have to charge at least $10 each tape.
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 12:09 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
One input record other input?
By Davron in forum Capturing and VCRReplies: 1Last Post: 30th Jan 2008, 17:20 -
FFMPEG and input A/R
By nic2k4 in forum Video ConversionReplies: 1Last Post: 14th Nov 2007, 19:39
