Results 1 to 30 of 39
  1. I recently bought an Optorite DVD Burner, and have been attempting to burn some DVD’s. I successfully created 2 data-only DVD’s right away with no problems whatsoever. In fact it worked great!
    Now I am trying to create a video DVD (backup of A Bug’s Life) and am having trouble getting these burnt discs to play in my Panasonic RV-31 DVD player and my Sharp DV-L70 portable player .
    I am using Philips 2.4 DVD+R discs for media and, according to the Panasonic player review for my model, it’s supposed to be able to play both DVD+/-R and the Sharp should be able to play DVD-R, but not DVD+R.
    I authored the VOB’s using DVD-lab and tested using Win DVD. Everything looks good. (Really like that DVD-lab!!)
    I am using Nero to burn and realize there are some problems regarding UDF 1.05 or whatever, so here’s what I tried:
    -Burned with DVD-ROM (UDF), UDF 1.02 > Panasonic can’t read, Sharp can’t read.
    -Burned with DVD-ROM (UDF/ISO), UDF 1.02 with all the ISO options unchecked (as described in the guide about burning with Nero) > Panasonic can’t read, Sharp can’t read.
    -Burned with DVD-VIDEO (I figured what the hell, I’ll try it) > Panasonic can’t read it. BUT, my Sharp portable COULD read this disc. (Interesting…)
    In all cases, WinDVD has played the burnt discs just fine.
    Any thoughts as to what I’m missing or what may be the problem here? My primary goal is to get discs to play on the Panasonic as this is my main player.
    Thanks in advance,
    Tim
  2. Banned
    May 2003
    Massachusetts
    Just a guess, but I'm thinking Mark Errors.
    - Gurm
  3. Did you check compatability?
    https://www.videohelp.com/dvdplayers
  4. Thanks for the responses so far....
    Gurm - What are Mark Errors?
    Thayne - I did check compatibility as I mentioned in my initial post.. Panasonic RV31 says it suports both DVD-/+R.
    Tompika - I have gotten one of the discs to play in the Sharp portable, and they ALL play fine on my PC using WinDVD4. I have also burned a couple data DVD's that came out perfectly... wouldn't this indicate that the burner is functioning correctly?
    Thanks again,
    Tim
  5. Banned
    May 2003
    Massachusetts
    I'm glad you asked, Timmy.
    Mark Errors are something that vance made up to explain why people have problems with copies.
    Don't worry, I doubt that's your problem.
    - Gurm
    Apr 2003
    N .IRELAND
    You will need to change the book type of your disc read here
    http://dvdplusrw.org/resources/bitsettings_pc.html
    :P
  7. Very interesting, goldmember1....
    So, if I'm reading this right, I should make sure the Book Type is set to DVD-ROM? Correct?
    Also, to perform a Firmware update, the instructions typically mention to boot into DOS mode.... I'm using Windows XP, so would I use the CMD line? Or do I need to create a Win XP startup disk? I'm unclear about updating the FW since Win XP doesn't have DOS (as I understand it, anyways)...
    Thanks so much for your assistance. I feel better already, LOL.
    Tim
  8. I've never heard that a dual burner was capable for bitsetting
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
    Apr 2003
    N .IRELAND
    No dual burners are capable of bitsetting yet & I’d forget a firmware update for that purpose. But keep a look out.
    Jun 2001
    Richmond , VA
    It would help if you told us in detail the steps you took .
    What version of nero are you using ?
    I have the same panasonic player and also use nero to burn .
    They play fine in mine .
    I can probably help you , I just need to know what you did .
  11. Using Nero 6 to burn. I have a VIDEO_TS and AUDIO_TS folder that I drag over for the compilation. The folders and VOB's were created by DVD Lab.
    I have tried burning as DVD-ROM (UDF), DVD-VIDEO and DVD-ROM (UDF/ISO), all to no avail.
    What else can I tell you that may help?
    Thanks,
    Tim
  12. interesting that this must be the fourth seperate post i've read regarding the same problem..with the same EXACT BURNER. Each time the standalone player was unable to play certain burned media when the specs of the standalone player said otherwise. While, in all cases, the specs don't mean much...i'd have to think this "OPTOWRITE" burner is doing something OPTO "WRONG" ....because it seems too conicidental that several people have to go the route of changing the book type in order to allow sucessful playback in their standalones.
    Man, if there's already these types of issues with the optowrite burner, i'd hate to even ATTEMPT to use the HD TECHNOLOGY....I can only imagine what might happen. The cdr's may only be playable on 2 of the 9 planets..and Earth not being one of them. However, if you change the book type to "CDROM" maybe a 3rd planet will allow playback.
  13. Banned
    Feb 2003
    Columbus, Ohio
    - Gurm
    gurm got problems
    he's mad that his mama told him "no, not tonite. i got a headache"
    timmyp
    that had nothing to do with your problem
    get you receipt and take that burner back and get a new one
    history of problems here
    gurm it's one thing for people to think you are fool
    it is another to open your mouth............. you know the rest
    you are showing your maturity level by posting this on every topic
  14. Banned
    May 2003
    Massachusetts
    Vance,
    You are showing your intelligence level by refusing to use capital letters and making "yo mama" jokes.
    I said I was gong to use your answer, that ought to make you HAPPY!
    You should be HAPPY that I too believe in Mark Errors!
    it's the new religion of the new millennium!
    - Gurm
  15. Banned
    Feb 2003
    Columbus, Ohio
    Vance,
    - Gurm
    this part edited by me
    i don't have to have your approval of typing
    when i was getting A's
    in calculus, p.o.d, Gym and every football and basketball and track award
    that you could get in high school
    you were get A' in typing, sewing and the glee club and getting your cheerleading awards
  16. Banned
    May 2003
    Massachusetts
    Ok, show of hands - who thinks Vance is resorting to childish name-calling?
    Hey Vance - I'll see your A in calculus, and raise you an A in Calculus 6 PLUS an A in "Functions of a Complex Variable". Yeah, here's a hint - I double majored in Math.
    Now hush. You're subliterate and you believe in bizarre things.
    AND you don't take criticism well. You resort to namecalling. I'm betting you're... 18? I would have guessed 12, but you claim to have taken calculus.
    Bragging about High School is so... err... what's the word? Oh yes - precollegiate.
    - Gurm
  17. Banned
    Feb 2003
    Columbus, Ohio
    - Gurm
    what do you think your hijacking topics shows?
    you must be all of 10
    i don't doubt what you say about your schooling
    you were type that came to school every day of every year. you were also the type that paid for my lunch.
  18. Banned
    May 2003
    Massachusetts
    So first you were an honors calc student. Now you're the school bully? Dude, stop bragging about beating up the smart kids - which didn't include me by the way. I was the one who broke your arm, remember? Kempo helps with that.
    You hijack every damn topic you can find with your "look it's mark errors" crap. And your "I know about it but I won't explain it because everyone says it doesn't exist" crap. Guess what? We say it doesn't exist... because it doesn't!
    And for the record, I was one of the kids who never went to class.
    Shows how much you know. Learn to type, learn to read, learn not to believe everything that the people at Pinnacle tell you. Upgrade your copy of Nero, and stop living in High School. This is the really real world. Some of us are trying to HELP the people on here.
    - Gurm
  19. What the **** is this MARK ERROR you guys are talking about?
    Sorry for hijacking the topic but the Optorite won't burn a good DVD+R
    anyway so I thought I could ask this.
  20. Banned
    May 2003
    Massachusetts
    I think there's an issue here with your drive. I think it has nothing to do with "mark errors". I was making a bad joke, because Vance has repeatedly posted to threads like this in the past.
    "Mark Errors", or "Marked Errors" are intentionally bad sectors on a disc, preventing it from being read/copied properly. The fact that these sectors are only checkable by SOFTWARE, and not by a DVD player, does not deter Vance from repeating his mantra.
    I apologize for any hijacking of the thread. Return to your regularly scheduled troubleshooting.
    - Gurm
  21. Banned
    Feb 2003
    Columbus, Ohio
    - Gurm
    first of all
    i wasn't the school bully
    but i did beat a lot of people up though
    but i got A's in everything too
    except typing
    i was called 'the intelligent hoodlum"
    but anyway i did whup up a couple of the 'know it alls', the 'you can't teach them anything' type of people like you
    i trying to be nice, so i suggest your "mary poppin's wannabee" butt drop the subject
  22. I have never seen so many problems with people with dual burners(mostly Sony) or Pioneer -R burners, I use a HP DVD200I +R burner and except for a couple bumps when I 1st started using it 10 months ago, since then I have not had a +R yet(no matter what brand I use) not burn correctly and then go ahead and play in any DVD player I put it in and I would say I have done around 300 to 350 burns on +R's and another 50 on +RW's.
    1st thing the bistsetter setting to burn as DVD-ROM makes it 100% playable in any DVD player/recorder( in the 50 or so I have tried), using Recordnow is a big plus over NERO.
    Am I saying the Sony or Pioneer's are bad, NO, just it may be more picky in setting them up and getting the right media to work with them.
  23. EXACTLY the same story here.
  24. Banned
    Feb 2003
    Columbus, Ohio
    Thanks in advance,
    Tim
    i apologized for the mess on this topic
    did you see this
    here about that burner
  25. You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  26. first of all
    except typing
    If you got a A in English and Grammer, your teacher should be fired!
  27. Originally Posted by thayne
    Isn't it GRAMMAR?
  28. Banned
    Feb 2003
    Columbus, Ohio
    now why do we got to go through this again,
    sissies always make fun of people grammar and english
    ok miss typing queen, you win
    i got a A in marked errors though
    p.s. to everybody else on this hijacked again subject,
    i apologize
