Results 1 to 9 of 9
  1. I have a Video_TS folder with all my VOBS, IFOs etc,
    But they are in PAL format. Is there a way to convert them to NTSC format?
    Please help me
    thanks
    -Luke
  2. Banned
    May 2003
    Massachusetts
    There are MASSIVE threads on this. Good luck, dude.
    - Gurm
  3. Where are these threads?
    I cant seem to find any on the main page, maybe my brains gone dead
    Can you post a link please,
    Thankyou
    -Luke
  4. Banned
    May 2003
    Massachusetts
    RIGHT ... BELOW ... THIS ... ONE.
    The one marked "DVD PAL to NTSC..."
    - Gurm
  5. That is about Encoding to ntsc with frame rates etc.
    I have a folder of Vob files, which I cant encode like that.
    OK? Can someone help me convert my VOB files to nstc?
    Cheers
    -Luke
    Mar 2003
    Uranus
    VOBs ARE MPEG2s (with extra stuff)
    You can frequently just put your VOBs where the
    MPEG2s go in the guides.
    You can also extract the MpEG2s from the VOBs first by demultiplexing the audio and video from them and muxing them
    back together.
    I found a new one step trick though. with MovieFactory2 you Import VOBs
    and then go look wherever it has it's working files and the MPEG2s
    will be there.
  7. lukebest88,
    Sorry man, but unless your standalone DVD player can play PAL DVD's there is no other way than to transcode your original.
    Pal got different frame rates and size that do not conform with NTSC.
    Like the last post said, check out some of the already existing posts.
    Listen to me now and believe me later
  8. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Read THIS thread here:
    https://www.videohelp.com/forum/viewtopic.php?t=160433
    If you can't follow that then don't bother and buy a DVD player that is region free and can convert PAL to NTSC on-the-fly while playing back a PAL DVD.
    - John "FulciLives" Coleman
  9. Thanks very much for all the replys, Encoding to MPEG2 while we speak.
    Thanks once again.
    -Luke
