  1. Anonymous
    Guest
    when trying to convert and svcd file, it comes out unplayable. it comes out pixelated and only shows about half the screen. the other half is green.
    it worked fine with vcd.
    here is a screenshot of what it looks like
  2. Hey,
    - did you repatch the vobs after authoring? If not try that.
    - does your play play svcds?
    - if you got a pioneer try the pioneer trick.
    Greatings,
    Yf
  3. Anonymous
    Guest
    i will try that vob patch....
    my player is fine. it looks like this on the computer. so i didnt even burn it yet
    Jan 2001
    montebello, ca, USA
    didnt realize i was posting as "guest"
    ok this is what im doing.
    all i want to do is put my SVCD movies on dvdr. as you can see above in the screenshot, this is what it looks like.
    i use vcd gear to extract the mpg
    then i use svcd2dvdmpg to made the compliant
    then i use tmpgenc dvd author to make the vobs
    and what u see in the screenshot is exactly what i get. i got that DVD Patcher program, but where in the process am i supposed to use it?
    Jan 2001
    montebello, ca, USA
    im still getting the green and is all pixelated....weird
    Jan 2001
    montebello, ca, USA
    and whats this about a pioneer fix? i have a pioneer dv353 and a dv333
    Jan 2001
    montebello, ca, USA
    ok i finally figured it out
    for anyone who read this and didnt know what to do...this is what i did
    exracted bins with vcdgear
    used (s)vcd2dvdmpg
    SVCD
    mpg to es
    720 and 1st header
    then used tmpgenc dvd author to make the vobs
    then used dvdpatcher to patch it back to 480 1st header
    then it was all goodie
