i was just wondoering if there is a tool available for this. I want to shift the audio in an mpeg to get the sync problems sorted. Some movies i can do fine, others not. Sometimes the audio is slightly out and its really annoying so i wanted a tool just to move it forward a second or back 0.3 secs etc.... thanks in advance
If you extract the audio to a file you could start it slightly after the video with say ulead movie factory or adobe premier 6
I think there's some setting in TMPGEnc, where you can offset the audio, but I usually convert the audio to wav, then add some silence / cut out some at the start of the wav, then encode. This of course only woks if the 'out of sync' is constant thruout the whole movie.
/Mats -
ok thanks for info gents. But is there a programme that can show me the changes i have made before i save it to see if the sync is ok?? otherwise its just a bit of a guessing game. thanks
Virtualdub does that. If you have MPEG1 file, Virtualdub does. If your file is a MPEG2, you have to use Vdub MPEG2 Mod.
In Vdub at Audio menu, select Interleaving and Audio Skew Correction.
Play video to certify.
When you know the amount of correction, you can demux, insert or delete a part at the beginning of audio to resync and remux.
What seems to be the best all in one video tool?
By ingeborgdot in forum Authoring (DVD)Replies: 51Last Post: 30th Aug 2008, 12:58 -
Is there any tool for me??
By kemcel in forum Video Streaming DownloadingReplies: 1Last Post: 9th Jul 2008, 23:16 -
Best Conversion Tool?
By cdaz in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 19:06 -
Which tool ?
By NICEBUD in forum Authoring (DVD)Replies: 7Last Post: 17th Jul 2007, 14:06 -
burning tool?
By yogart in forum Authoring (DVD)Replies: 8Last Post: 25th May 2007, 14:20
