Have this video with AC3 and i used besweet to extract the video and save it in wav fornat.Used my usual way of using Virtualdub and TMPGEnc to add in the subtitles and encode the wav in but the final video got no sound.Help anyone???
I presume you mean the audio mate?Originally Posted by uRiZEn
If so, have you listened to the resulting wav file? and do you know what format the wav is (e.g. PCM etc..) is there anything there?
If I run into trouble with AC3 audio, I usually load the entire source file into GoldWave, then save as a 16-bit PCM wav (GoldWave discards the video portion of the stream and saves just the audio portion). Then you can do what you like with it (you often have to normalise the wav, as it can come out pretty quiet).
cheers,
mcdruid.
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 20th Jun 2011, 23:56 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 00:10
