Hi all,
i just found a load of rubbish in file in c drive and i was wondering if its safe to delete, the file directory is
C:\Documents and Settings\my username\.jpi_cache\file\1.0 and is there anyway to automatically clear the contents after i come off the net? im using xp home as my operating system
thanks
kas
The files belong to Netscape's Java Plug-in. I use this for the Netscape browser only. It is best to leave as is otherwise the Netscape settings will be affected and won’t load. You need to reinstall the browser again to correct it.Originally Posted by kas187
If you don't use Netscape and its Java plug-in then you can remove it provided that Netscape is uninstalled and the Java not in use for Internet Explorer.
If you don't want the java installed for Netscape or Internet Explorer you have use the Control Panel's removal of programs and you must re-install the Netscape again if you want the broswer without the java plug-in.
The Java plug-in is best for Netscape only and wouldn’t advise using it in Internet Explorer. You don’t really need it using IE6.
Safe internet use for guests
By edong in forum ComputerReplies: 8Last Post: 28th Mar 2011, 16:23 -
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 15:30 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
TV Safe Colors ?
By Mike99 in forum Authoring (DVD)Replies: 31Last Post: 13th Nov 2008, 03:01 -
safe mode screen?
By alintatoc in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2007, 17:27
