Hi there,
I was wondering guys...... Is there somewhere a tool which can make Motion Menu (main menu) for DVD Maestro. Normally I use DVD Menu Studio. But this tool can't make motion menu's.
thx![]()
Hi freestyler,
thx for quick response.
Is there somewhere a guide? I also own Vegas 4.0, but i've never done it before..
thx -
Motion menus are nothing more than regular MPEG files with a subpicture to define the buttons. So you just generate a m2v file as normal. You can do this with several programs: VDub, Permerie, Vegas Video, Ulead, Cool3D, etc. etc.
Once you have the video take a screen capture of it (you can do this from within Maestro) load it up in DVD Menu studio and then generate the subpictures are normal. -
thx spectroelectro
I've seen this post. I'm going to give it a try tonight when i'm at home.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
Motion menu thumbs in DVD Workshop 2
By milway in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2008, 08:12 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
Editing Motion DVD Menu
By gallardo in forum Authoring (DVD)Replies: 5Last Post: 6th Nov 2007, 22:12
