Just the drivers to even run properly in windows. I got an OEM, and it isn't picking it up properly.
Results 1 to 9 of 9
What Operating System? You got nutting in profile....
I got a drivers' CD that came with my NEC drive, PM me if need be. -
It's windows XP, it reads it just as CD Drive and doesn't let me see it as a recorder in any programs, nor the hardware profile thing.
I have the same DVD +- dual writer as you and winxp pro detected it right away. Although I got a driver cd with mine I really didn't need it.
Try uninstalling the cd drive that windows found by removing it from the system device list ... control panel/system/hardware/device manager/dvd/cd-rom drives and right click and uninstall. Reboot and let windows find it again.
If that does not work then it could be that you have not maintained your xp updates ie..service pack1 and ms patch updates. This is a relatively newer drive and may not show up on older versions of xp. To check go to your start menu/ all programs and choose windows update. You can let ms scan your installation to see what updates are needed.
Another (less likely) cause may be that the device is misread because of a conflict due to not properly setting the master/slave jumpers on the drive if multiple devices are on the same ide controller.
I suppose you have already scanned the NEC sites to see if they offer the drivers online.There's not much to do but then I can't do much anyway. -
Originally Posted by Dilbert135Swift Kick In The Butt $1.00
"Everybody I know needs what I'm selling!" - Calvin -
The drivers' CD I got with my drive are for XP exclusively, I got Win2K and it did recognize the drive properly.
I can just email you the drivers or put them on my webspace and give you the link so that you can download them at your convenience. -
I'm at a loss here. What driver? ASPI? XP does not need a 'driver' to use the drive. If you are running in DOS, then yes you will need the dos driver.
XP only reads it as a CD-ROM, not a DVD drive. If you could put up the drivers I'd appriciate it.
Help! Where Do I Get New Drivers?
By RayPaula in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Jan 2010, 09:13 -
Is this the correct way to find XP drivers?
By vid83 in forum ComputerReplies: 11Last Post: 3rd Mar 2009, 10:38 -
Looking very hard to find these drivers....
By MidnightMike in forum ComputerReplies: 8Last Post: 2nd Nov 2008, 12:34 -
where to find Vista drivers for EMPIA 2821 usb de´vice (BT-TTU305B)
By anglerdk in forum Capturing and VCRReplies: 6Last Post: 27th Sep 2007, 17:23 -
drivers
By Mr anderson in forum ComputerReplies: 2Last Post: 29th May 2007, 04:36
