I have some mpeg2 files that were re-encoded from mpeg to mpeg2 format. The video is not that bad, as a matter of fact it is quite good BUT I have avi files of the same show with excellent quality video.
My question is: If I were to encode the video portion of the avi to mpeg2, rip the audio from my existing mpeg2's would I need a basic editor to join the two(without a/v sync errors) or should I go the more expensive route and use a timeline based editor.
Thanks for any and all replies!!![]()
Why not re-encode the audio and video together?
Going the other way would just require a re-mux tool, wouldn't save much time, and would be more likely to have synch issues. -
I don't know if it's like this with everyone BUT everytime I post a question here usually within 12 hours I always find the answer BEFORE I check my post.
I loaded the video portion of the avi I have and then ripped the audio from the mpeg2 I have and combined them together and SO FAR, no A/V sync porblems.
The only reason I was asking the previous question was due to the fact of the mpeg2 file being edited (I cut the commercials out) and I did not think the sync would line up correctly. Vegas Video worked like a charm, like I said before, SO FAR. I now have to do a test burn to see if it will be ok in dvd format on my stand alone.
If there's anything else pleas elet me know!!
Thanks again!!
New to Was Editor
By HoosierGuy in forum EditingReplies: 5Last Post: 23rd Jan 2011, 17:52 -
conversion or different editor...
By krohm in forum EditingReplies: 12Last Post: 25th Jul 2010, 10:06 -
Good basic vid editor that can handle .mp4 movies from FujiFilm S2000HD cam
By coffeecup-sf in forum EditingReplies: 3Last Post: 21st Jun 2010, 22:24 -
DV Editor
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 11th Sep 2008, 12:43 -
Editor app...
By cwb in forum EditingReplies: 9Last Post: 20th May 2007, 02:32
