[i dont speak english]
I try using Adobe Encore DVD 1.0.0.35761 build.
This is on "trial" version.
It's works fine, but in my XP when chose option BUIL DVD, the process start and crash in ENCODE AUDIO STREAM.
"No encoder for this audio"
"NO AC3 audio decoder"
But i transcoding all audio files in A.E.D.(Adobe Encore Dvd) and NO error!
And preview works fine! All files OK!
The audio and vidoe files had been made in the TMPGEnc! [M2V,WAV]
I dont have idea this bug!
Somebody can help me?
Well, taking off bug, this program is best!
Motion Menus, Motions Butons, Free TEXT in menu, Free Sub-menus, Easy photos slides with audio, full suport for another ADOBE softwares, etc.
Excelent!! But my version is BUG. Wait for another version...
Closed Thread
Dude how did you get Adobe Encore DVD? I am going to buy it in the Video Production Set thingy when it comes out because it looks awsome. Anyway maybe your not using a supported Audio type, Or since the program isn't even out yet you just have like a test version and it is a bug. that would be my guess. well........sorry I couldnt help but good luck anyway
[i donīt speak english]
Hi!
I caught this version with friends. They had said me that it was a trial. It is completely basic, does not have help,library, etc. This same version is available in softwares p2p
. I looked at in the ADOBE.COM and vi that it not possue trial version
, then I do not know where they had obtained this.
But, it is a functional version and is professional software!
[quote="Carkey"]Dude how did you get Adobe Encore DVD? I am going to buy it in the Video Production Set thingy when it comes out because it looks awsome....
You are in breach of the forum rules and are being issued with a formal warning. NO WAREZ
/ Moderator BJ_M
I dont speak english! what it is BS?Originally Posted by SHS
It is really a version beta. I to obtain to test. It is an excellent software. I already used: Ulead Movie Factory, DVDit, DVD Teacher, BS DVD, ROXIO DVD, etc.
But ADOBE is ADOBE!
If the tests will be good I buy ADOBE ENCORE DVD. I live in America of the South, it cost u$599.
High price for common users!
If you work and depend on this, buy!
that is a early beta and many things dont work and under the terms of the beta users NDA you can not even talk about it .
that you have it, means it is warez ... adobe is anal about such things, throws the book at anyone they catch with thier products as warz or breaks their legaly binding NDA ...
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 07:30 -
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 20:24 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
