Ok I have a DivX file, 23.96 frames/sec as says Virtualdub.
I try to create an MPEG-2 from this using TMPGEnc using NTSC film with VBR 2-pass. For some reason when I play the resulting file in Windows Media Player... I cannot seek within the file.
If I try to encode this file with CBR, I get the following error popup from TMPGenc "-272762941 859034592" several times!
VirtualDub also warns me that the audio in this DivX file is VBR.
Help please!!!!!!!
Open it in Vdub, set video to direct stream copy and audio to full process and make it uncompressed wav then save as a new avi. you may want to go into the audio properties (Under conversion) and set it to re-encode to 44,100Hz too
You'll need VDub-MP3 though. I prefer GoldWave for VBR or AC3 audio extraction, here's a guide.
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 22:59 -
Converting VBR avi Xvid/divX to wmv9
By surfmonkee in forum Portable VideoReplies: 4Last Post: 17th Nov 2008, 02:54 -
WMV3 and WMSpeech to Divx and mp3 VBR
By logicom in forum Video ConversionReplies: 6Last Post: 19th Oct 2008, 16:31 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 15:51 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
