I just downloaded a flick, and I can't seem to get TMPG to read it. The file is avi. and I dont know what to do.... I have a vcdburner and some other code thing downloaded. Could someone please walk me through this.
Results 1 to 11 of 11
My advice to you is to read the Convert guides over there on the left ...and be patient ...we all had to learn the hard way ..trial and error patience and persistance not by demanding help quickly
Converting a file is by now means a quck process converting the file can take anywhere from 20mins up to 40hrs.....quick is not an optionHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
You have most likely downloaded a divx file actuallyi would say that you have. Download the latest Divx codec. once installed Tmpenc should read it
then once it is done you will be able to burn it using a burning program like Nero using vcd templateHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
Codecs are required for your PC to recognize and access AVI files. There are some common audio and video codecs that are used, to identify which one (ones?) that you require you can use a program called Gspot. It's in the Tools section and will test your file and tell you what is needed and if it's installed on your system. Get the codecs you need and install them in order to convert your file.
BTW, I'm not sure if I understand your reference but if you're talking about a commercial movie that you d/l'd, then please be more careful. Direct references to such material is against forum rules."Art is making something out of nothing and selling it." - Frank Zappa -
did it, it says I have all that I need, but it still says the avi. file is invalid.
Could be a bogus file.Originally Posted by Airswish99
all video convertor worked, but it will take a while, ummm i said something like it will say something on the screen... anyone know if it what it meant, and if it is reliable?
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 10:45 -
New here - Quick questions
By ImportGuyR34 in forum Authoring (DVD)Replies: 6Last Post: 10th Mar 2011, 08:11 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 18:14 -
Aften - Is it really that quick?
By 44echo in forum AudioReplies: 20Last Post: 30th Dec 2009, 23:04 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 17:38
