I'm looking into buying a 100 pack of dvd-r media.
I've been using ritek dvd-r media and it seems to be working perfectly on all my stand alone dvd players.
I was wondering if there were any other type of media that would work on my standalone dvd players. I'm mostly gonna be recording dvd movies and wanna make sure they work on most stand alone dvd players.
I know that the cheap princo's don't work on my toshiba sd-1200
But what about the newer 4x princo media?
What about optodisc, samsung, taiyo, DupEZ media?
Any info would be greatly appreciated!!
I'm looking to save a few bucks. Don't wanna shell out $139 for ritek 4x media. But if I don't have any other choice, I will. THANKS!!
i would say stick with what you have as you know it works and they are good quality ..
any decent quality should work. its more a matter of the process you use to burn it than the media itself. I've had excellent luck with maxell and sony media.
Originally Posted by Poppa_Meth
i would say it is both ... the media makes a LOT of differance if you want max. compatibility .. -
I've got a promotional DVD that I need to copy and distribute to potential customers.
Can anyone recommend whether I should use DVD + or - for maximum compatability with stand alone DVD players?
Also, depending on what you recommend, can you specify a brand and a UK source for them - I'm after approx 30 copies.
Pete -
you can + or -
you want a nice good looking disk -- just pick up some apple brand disks ..
very consistant quality
A Media Player That Actually Works On A 64 Bit System
By JayLovesKasesSky in forum Software PlayingReplies: 24Last Post: 5th Oct 2013, 08:06 -
Recommend stand alone media player that supports FLV files?
By peggypwr1 in forum Newbie / General discussionsReplies: 12Last Post: 11th Jan 2012, 04:01 -
Adivce on purchasing a stand alone media player online
By Cornholio77 in forum Newbie / General discussionsReplies: 17Last Post: 26th May 2011, 09:04 -
non-latin characters for stand-alone media player subtitles
By sonam in forum SubtitleReplies: 4Last Post: 27th Nov 2010, 19:30 -
Media Player that works with MCE Remote
By TBoneit in forum Software PlayingReplies: 2Last Post: 30th May 2007, 17:13
