I just bought an LG GMA-4020B and burned one dvd on the dvd-rw disk provided (Maxell) using DVDDecripter and IC. No problems. I also have burned dvd's onto dvd-r media (Memorex). No problems. When I try to burn onto Memorex dvd-rw I keep getting write error messages. I'm wondering if my first burn onto the Maxell dvd-rw was a fluke. Do I need to set any special settings in IC or are the Memorex dvd-rw disks the problem? Thanks in advance for any help.
Yeap, you are right, Memorex DVD-RW disks are to blame. I bought a pack along with my burner and the disks never worked, I was lucky they took the the disks (open) back.
Do a search under DVD Media and DVD Writers for -RW media that works with your burner.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
