Deep analysis can be used from the file pull down menu after loading the movie and after starting the back-up as an option. Does it matter which deep analysis? Are they the same? I have been doing the Deep analysis during the back-up only. Also if there is No compression is there any reason to do a deep analysis?
No its not need becuase you are not compressing anything. Its only need when you have a large film. It might take a little longer but produces better video quality.Also if there is No compression is there any reason to do a deep analysis?
It takes f***ing long (about 40min @7.5GB) but it's worth....Originally Posted by AND1
Question about DVDshrink and lossless copying
By sasuweh in forum Authoring (DVD)Replies: 5Last Post: 5th Oct 2010, 13:08 -
DvdShrink question?
By Loader09 in forum DVD RippingReplies: 2Last Post: 13th Nov 2009, 12:10 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
"DVDshrink - Vista where is Application Data Analysis files located?
By mn072065 in forum DVD RippingReplies: 2Last Post: 24th Feb 2008, 17:43 -
dvdshrink question...
By cyane30 in forum Newbie / General discussionsReplies: 6Last Post: 1st Nov 2007, 14:14
