  1. Does anyone know why in WIn2000 I am still getting disk full error messsges when the capture reaches 4GB. Doesnt seem to matter what capture prog I use.....
  2. If you are using a FAT-32 disk partition, then you are still limited to 4GB files. You must use an NTFS formatted partition to go over 4GB.
    (your capture program should also support the Open-DML 2 standard for large AVI files)
  3. What file-system are you using, FAT32 or NTFS? FAT32 has a 4 gb file limit.
  4. Darkbird, you beat me with 3 min!
  5. Yes I am using FAT32. WIll changing to NTFS have any detrimental effects on performance or compatability??
  6. and lastly what does the OPEN DML-2 do??
