I paid for the + version, downloaded the program and the reg file.
But when i installed the program and movedthe reg file intothe same directory i got errors when i launched the proble. it just wanted to connect to the internet, the problem is that pc doesnt have the internet, so does that mean i cant install it???
Can someone help me out
lee
The program updates itself the first time it is run via the net. If you are not connected to the net then you can go to updates+ on my site & get the relevent updates from there from a PC on the net and copy them to the non networked PC.
Guest
I copied the files from the website and putthem into the svcd folder, but when i started the program it still launched pages wanting the internet???
So you downloaded the update zip files from the website and unzipped them into your svcd2dvdmpg+ folder? What is the build number & file size of your svcd2dvdmpg+.exe file?
Hmm so the download files, even those that were zip files, did i have to individually unzip them all and enter the files into the svcd folder, as when i looked zip files of the same name were in there so i presumed i didnt have to unzip them further is this right?
I dont know the build no or filesize of the file as im at work. -
From the updates page:
Clicking on the download icon next to a file name will prompt you to download the file in question, zipped up. You must then unzip the file to the svcd2dvd install folder.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
BDRebuilder Probles with Star Wars BDs
By Zentik in forum Blu-ray RippingReplies: 13Last Post: 18th Sep 2011, 12:56 -
installing win95 on hd that has xp
By mac71671 in forum ComputerReplies: 15Last Post: 18th Feb 2009, 21:08 -
Installing XP on a used PC
By CSULB71 in forum ComputerReplies: 24Last Post: 21st Nov 2008, 12:05 -
installing
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Mar 2008, 08:13 -
Um, now what? I'm stuck - SVCD2DVDMPG usage
By Hal05154 in forum Video ConversionReplies: 4Last Post: 13th Aug 2007, 09:59
