I have one main menu and four sub-menus. I added the same audio file as background music for each menu. The main menu is fine but the others have a problem. The audio plays for a fraction of a second and then starts over continuously. The DVD player (standalone) timer keeps flashing on and off for these problems menus. Navigation is difficult. The only thing I can think of is that the same audio shouldn't be used for all the menus but I don't see why that would be a problem.
I don't think that DVD Lab supports music in sub menus, only the main menu.
you might go over to the DVD Lab forum - I don't have the address at work, but you can follow the links from www.mediachance.com- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
So far, I didn't noticed any problem with this beta version. But I am only using it since yesterday. Until now, no crashes.
I've done this successfully with one main menu and 5 sub-menus doing the exact same thing. I used the same background music asset for every menu without any problems.
I'm using the latest beta version and haven't seen any real problems with it.
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 13:54 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 16:02 -
Cell Menus Dvd lab pro
By angelus214 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 10:52 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 19:10
