I have Pinnacle Studio with a/v input and recently just bought Snazzi III USB.
My pc's spec are P4 1,8 Mhz with 512 DDR and USB 2.0.
I captured from Analog camcorder which is in Hi8 format.
With Pinnacle, I captured to AVI files then using Studio 8 the avi was edited and
converted to MPEG 1 (VCD)
it looked like this :
With Snazzi III USB, I Captured to MPEG 2 (DVD) with the highest bitrate using Movie Mill
2.1 build 57, then edited the mpeg 2 file and converted to MPEG 1 (VCD)
the result as shown :
Why is it better picture with Pinnacle studio?
Both screen shots are from the AVSEQ01.DAT (File inside a VCD DISC)
Is there any setting that I need to change to achieve at least same if not better with the
old Pinnacle Studio Card?
Or is the Snazzi III USB just not a better product to do this VCD capturing?
Tried Capturing directly to VCD format using Snazzi III USB, edited and result is worse than
the method I use above.
I also have tried to edit the mpeg 2 using studio 8 and converted using TMPENC with highest Quality (SLOW),
Noise reduction activated, It is still no better than the one I captured with Pinnacle Studio
Results 1 to 1 of 1
Capturing Video 8 with optimum quality
By bwt in forum Capturing and VCRReplies: 7Last Post: 1st Sep 2011, 22:52 -
capturing high-quality streams
By topquark in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2010, 02:12 -
Capturing still images - keep quality
By CharlesH in forum Capturing and VCRReplies: 1Last Post: 6th Apr 2010, 19:39 -
what is the best program 4 capturing???i need one with good quality
By khalid81 in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2009, 21:13 -
bad quality after capturing by FireWire
By Medes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Oct 2008, 08:08
