  1. has anyone ripped the tv series 24, ive had problem doing this with DVD Shrink and clone dvd with decrypter and any dvd. Could anyone shed any light on how to get round this cos im not sure why i cant do it.
    Thanks.
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    well try being more specific.
    Can your ripper not find the correct key?
    Will it not recognise the disc?
    is your output garbled?
    are you out of hard drive space?
    what is the actual problem?
  3. it stops during encoding and gives no reason.
  4. please tell us the software you use. Try Smart ripper rip to the hard drive then rip from the hard drive to other folder in the hard drive. i had to do this one time.
  5. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    *holds hands in front of himself*
    My god, i'm being attacked by a -deluge- of information!!
    What software are you using, what process are you doing, what guide are you following and what are you trying to output to? we need specifics.
    Dec 2002
    There is nothing special about the 24 DVD's, it's a standard DVD9 'EP' series, follow any of the guides relating to it (Star Trek, Friends, Sopranos, are all done the smae way).
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  7. i have already said the software im using are you blind?
    dont need a guide to use clone dvd, a lobotomised monkey could use it.
    take it easy man.
    on clonedvd its just stopping at 99% during encoding all the time and the error message says "no reason".
    and shrink aint doin it at all.
    and i wanted to know another straight forward way to do it while keeping menus.
    or if anyone know why clone could be doin this.
    thanks.
