  1. SVCD2DVDMPG+
    How do you get the above software
    I paid a £5 donation as it said on the website but havent had an email about it yet or the link to download it ????
    I'm moving you to the SVCD2DVDMPG forum. I think chrissyboy(the creator of svcd2dvdmpg) should be able to help you.
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Indeed. Thanks baldrick.
    @leeegglestone: it was sent to your AOL email as that is what you used. I have since spotted your request to send it to another addy - which i have done. So you should have it in at least two places now.
    CB
  4. Thankyou, now ive had trouble getting it to work
    I installed the big file, then added the reg file in the same directory but then when i tried to run the program it wanted to start up the internet. I dont have the internet on that pc, does it mean i cant run it then???
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
