I have been using ffmpegX successfully to backup my DVD collection to divX AVIs. I use 0SEx 0.0101b to create a single VOB file on my hard drive, then use the ffmpegX quick preset 'divX' to convert it. However, a few DVDs (say, 5%), when converted to divX, lose their soundtrack completely.
I have tried choosing every audio track from 0 to 9 in the 'audio track' section, and have tried the 'invert mapping' box as well. Nothing seems to help. When I view the VOB file using vlc, the soundtrack is present. FfmpegX just can't seem to 'find it'!
Any tips/workarounds would be greatly appreciated!
Here is the Terminal output for one of these 'audio missing' conversions:
Last login: Mon Aug 11 15:46:44 on ttyp1
pbpaste | sh
Welcome to Darwin!
[Greg-Andresens-Computer:~] gregandresen% pbpaste | sh
Encoding started on Mon Aug 11 17:20:04 EST 2003
Using GNU internationalization
Original domain: messages
Original dirname: /sw/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
Reading /Users/gregandresen/.mplayer/codecs.conf: can't open '/Users/gregandresen/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Using built-in default codecs.conf
File not found: 'frameno.avi'
Reading config file /Users/gregandresen/.mplayer/mencoder: No such file or directory
init_freetype
Using Unoptimized OnScreenDisplay
Not an URL!
File size is 2835486720 bytes
success: format: 0 data: 0x0 - 0xA9021800
Checking for YUV4MPEG2
DEMUXER: freeing demuxer at 0xe38550
ASF_check: not ASF guid!
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
Searching demuxer type for filename /Volumes/Macintosh HD/TITLE02-ANGLE1.VOB ext: .VOB
Trying demuxer 2 based on filename extension
system stream synced at 0x0 (13)!
==> Found video stream: 0
MPEG-PS file format detected.
==> Found audio stream: 160
Too many video packets in the buffer: (4096 in 8093058 bytes).
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
ds_fill_buffer: EOF reached (stream: audio)
MPEG: No audio stream found -> no sound.
Searching for sequence header... OK!
VIDEO: MPEG2 720x480 (aspect 2) 29.97 fps 6750.0 kbps (843.8 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening video filter: [expand=-1:-1:-1:-1:1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale=352:240]
SwScale params: 352 x 240 (-1=no scaling)
Opening video filter: [cropdetect]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred csp: Mpeg PES)
Trying filter chain: cropdetect scale expand lavc
Could not find matching colorspace - retrying with -vop scale...
Opening video filter: [scale]
SwScale params: -1 x -1 (-1=no scaling)
Trying filter chain: scale cropdetect scale expand lavc
The selected video_out device is incompatible with this codec.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder v2.0
libmpeg2: No accelerated IDCT transform found
libmpeg2: No accelerated motion compensation found
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
VO Config (720x480->720x540,flags=0,'MPlayer',0x32315659)
REQ: flags=0x441 req=0x0
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using C
SwScaler: using FAST_BILINEAR C scaler for horizontal scaling
SwScaler: using n-tap C scaler for vertical scaling (YV12 like)
SwScaler: 720x480 -> 352x240
REQ: flags=0x401 req=0x0
videocodec: libavcodec (352x240 fourcc=58564944 [XVID])
High quality encoding selected (non real time)!
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
Writing AVI header...
*** [cropdetect] Allocating mp_image_t, 720x480x12bpp YUV planar, 518400 bytes
Pos: 0.0s 1f ( 1%) 0fps Trem: 0min 0mb A-V:0.000 [0:0] A/Vms 0/27 *** [cropdetect] Allocating mp_image_t, 720x480x12bpp YUV planar, 518400 bytes
*** [scale] Exporting mp_image_t, 720x480x12bpp YUV planar, 518400 bytes
*** [lavc] Allocating mp_image_t, 352x240x12bpp YUV planar, 126720 bytes
*** [expand] Direct Rendering mp_image_t, 352x240x12bpp YUV planar, 126720 bytes
get_path('subfont.ttf') -> '/Users/gregandresen/.mplayer/subfont.ttf'
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
Pos: 0.0s 2f ( 1%) 0fps Trem: 0min 0mb A-V:0.000 [0:0] A/Vms 0/100*** [cropdetect] Allocating mp_image_t, 720x480x12bpp YUV planar, 518400 bytes
// output truncated here //
Pos: 5.0s 150f ( 1%) 5fps Trem: 24min 36mb A-V:0.000 [1204:0] A/Vms 0/179 D/B/S 0/1/0
Writing AVI index...
Fixing AVI header...
Video stream: 1204.698 kbit/s (150587 bps) size: 748665 bytes 4.972 secs 150 frames
uninit video: libmpeg2
DEMUXER: freeing demuxer at 0xe38f10
DEMUXER: freeing sh_video at 0xe398d0
DEMUXER: freeing sh_audio at 0xe3b0d0
Encoding completed on Mon Aug 11 17:20:35 EST 2003
App for converting .vob folders/files to DIVX or XVID?
By Newb787 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2011, 14:21 -
Convert VOB files to Divx with DVD menu
By xtof in forum Video ConversionReplies: 1Last Post: 1st Mar 2011, 15:29 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Do avi/divX files that come from DVDs preserve audio channel information?
By quitearush in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 03:40 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
