I have a question regarding the conversion of a VOB file to AVI for editing in Premiere.
This is the first time that I've tried to rip, edit, re-author, and re-burn VOB files from a DVD that I previously authored.
First I copied the VOB files to my hard drive.
Then, using the suggestions in one of the forums, I used Virtualdub MPEG-2 to convert to AVI.
I ran the program on the first VOB file (~1.4GB) and got the following unexpected results:
1) the AVI file is 48 GB (video length is approx 24 min). I would have expected the file to be only about 8 GB (I believe rule of thumb is 4 GB = 13 min of AVI).
2) the AVI file has no sound (when played in WMP).
3) I cannot import the AVI to my video bin in Premiere. It tells me that the file type is not supported.
Am I doing something wrong? All I did was open the VOB in VirtualDub and then selected SAVE AS AVI.
Is there a different way to edit VOBs? Basically I want to take the footage off the authored DVD, cut it down into a clip show, and then re-author a new DVD with as little quality loss as possible.
Also, what really is a VOB file with respect to an MPEG-2 (without getting into ugly details).
Thanks.
Perhaps you should use a AVI codec to save your movie to. Also, since DVD sudio is usually AC3. you may be missing an AC3 audio codec.
Hello. -
the default setting for codecs is "Uncompressed", so you saved it as a big block of uncompressed video. You need to go under Video->Compression and select a codec.Am I doing something wrong? All I did was open the VOB in Virtualdub and then selected SAVE AS AVI.
You can use something like Chopper or ChopperXP to cut the vobs directly and save them. Then import them into authoring software that supports vob files.Is there a different way to edit VOBs? Basically I want to take the footage off the authored DVD, cut it down into a clip show, and then re-author a new DVD with as little quality loss as possible.
check The GlossaryAlso, what really is a VOB file with respect to an MPEG-2 (without getting into ugly details).- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I was able to open an MPEG2 directly in Premiere,
but not a VOB. It will have to be re-encoded if I edit it.
I think you should just cut & join the VOB or at worst
extract the MPEG2 and edit that. -
I was not successful in my re-attempt last nite.
My problem is my lack of knowledge of codecs. There are quite a few audio and video codecs to choose from in VirtualDub. How do I know which I should choose?
I selected Indeo for video and MP3 for audio.
It generated a 2.5 GB file (huge difference compared to the 48 GB file).
There was still no audio when playing back in WMP.
When I tried to import the AVI to a bin in Premiere I still got the same error message: format not supported.
What am I doing wrong? The VirtualDub "help" is too advanced for me.
Does anyone know if there is a tutorial on codecs anywhere? -
you used the right codec for video but MPEG Layer 3 for audio is not a compatible codec for premiere,it may work ok but is preferable to use a PCM codec in virtualdub,something like ADPCM.
for video you can install and use PICVideo MJPEG codec is well if you want the avi files to be much smaller.
Combining VOB & AC3 to DV AVI Files for Editing in Premiere Pro CS4
By foochuck in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 15:08 -
VOB to AVI to import into Premiere CS3
By newcomer1 in forum DVD RippingReplies: 6Last Post: 11th Mar 2009, 16:32 -
VOB to DV-AVI to Premiere - Yes, I have done my homework
By bpalmer in forum Video ConversionReplies: 14Last Post: 9th Mar 2009, 23:47 -
converting m2ts for editing in Premiere Pro 1.5 and buring to DVD
By Trenidor in forum Authoring (DVD)Replies: 6Last Post: 3rd Jun 2008, 00:28 -
Converting VOB to DV AVI for Premiere 6.0
By wasimismail in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 9th May 2008, 23:20
