Hi,
I have these 2 programs and like to know if there is a major difference between these 2 versions? Cos I have an avi of about 700mb and like to convert to mpg. I have only tried the freeware before and one time got out of sync problem. Now when I tried to convert with the pro version it says it needs about 7 hours to do the convertion. With the other version it only takes me only half of that time. So which version should I use? Is there a real difference in quality?
thank you
As far as I am aware the only difference with the plus version is that it does MPEG 2
Avoid "Motion Search Precision: Highest Quality (very slow)" and any Filters ... but you'll loose quality !!!!
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
TMPGEnc Products - Notice Difference
By niteghost in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 20:15 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 19:48 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
