Hi,
I've made already a couple of DVDs with DVD lab w/o any problems.
Now I've put two movies on 1 disc, compiled the DVD disc... and it doesn't have audio when played on my PC or my desktop player
when I play the vob files (so not as a DVD, but as a file) the sound is played... so it is encoded in the vob, but when played as a dvd disc the sound is not available
please help, as I go mad shortly
thanks
Zoltan
And are all your sound files *exactly* the same encoding? And you don't have any background menu sound do you?
In DVDLab it only supports sound files that are all encoded at exactly the same encoding rate and are the same type. When you bring your audio files into DVDLab what does it report them as?"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
In this case no menu background audio, and the other two audio files for the two movies I use are the same type same rate.
I'll try force audio...
thanks,
Zoltan
DVD Video made with PiTiVi and DeVeDe -- no sound. How do I proceed?
By VanillaMozilla in forum EditingReplies: 8Last Post: 7th Mar 2011, 12:02 -
Frame made in dvd lab pro 2
By PharmBoy in forum Authoring (DVD)Replies: 5Last Post: 28th Apr 2008, 23:57 -
Editing Nero made DVDs: DVDauthorgui? dvd lab pro? Gui4dvdauthor?
By KneeRow in forum Authoring (DVD)Replies: 31Last Post: 22nd Aug 2007, 02:41 -
No sound on dvd burned with convertx2dvd made from ratdvd
By maureensullivan in forum Newbie / General discussionsReplies: 10Last Post: 5th Aug 2007, 19:41 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
