I'm trying to make my own compilation of a few music DVD's. They all have AC3 audio, and Ulead won't accept it. I have to convert the audio to wavs. No big deal, I guess, but is there any available software that will directly accept the AC3 sound on the music clips?
Results 1 to 14 of 14
You dont say which ulead product you are using. Ulead DVD Workshop (without the AC3 plug-in) will accept AC3 audio providing it is muxed with the video.
Originally Posted by Bob W
According to another post Ulead DVD MovieFactory 2's IMPORT DVD button will import it.
If you don't *edit* the AC-3 audio, you can make Ulead DVD MovieFactory 2 pass it through to the disc that you record by checking the DO NOT CONVERT COMPLIANT FILES check box.
If you try to *edit* the AC-3 audio, however, Ulead DVD MovieFactory 2 (the non "LE" version) will re-encode it to either LPCM or MPEG audio."Can You Dig It!" -
Originally Posted by bigb_y2g
Even Ulead's non-AC-3 video editing and DVD authoring applications will not re-encode AC-3 MPEG source files if the user understands the limitations.
Consider...
1. DVD MovieFactory 2
http://www.ulead.com/dmf/runme.htm
...and...
2. Ulead Videostudio 7
http://www.ulead.com/vs/runme.htm
While these two Ulead applications do not have the native ability to CONVERT NON AC-3 audio MPEG sources into MPEGs with AC-3 audio...
...they do *NOT* re-encode unedited, AC-3 SOURCE MPEGs when burning to disc IF ONE FOLLOWS THE CORRECT STEPS.
In my testing, I have routinely succeeded in burning AC-3 MPEGs to DVD-RW using Ulead DVD MovieFactory 2 and Ulead VideoStudio 7's disc authoring module.
In Ulead VideoStudio's disc authoring module...
1. I opened ULEAD VideoStudio 7.0;
2. I clicked SHARE > CREATE DISC;
3. I clicked the button in the far lower left hand corner of the disc authoring module;
4. I clicked DISC TEMPLATE MANAGER;
These were the settings I chose:
MPEG files
24 Bits, 720 x 480, 29.97 fps
Field Order A
(DVD-NTSC), 4:3
Video data rate: 8000 kbps
LPCM Audio, 48 KHz, Stereo
5. I then clicked CLOSE;
6. I then clicked the SECOND button in the lower left hand corner of the disc authoring module;
7. I checked to make certain the PROJECT SETTINGS were as follows:
MPEG files
Field Order A
(DVD-NTSC), 4:3
8. I then UNCHECKED and then RECHECKED the DO NOT CONVERT COMPLIANT MPEG FILES box;
9. I then clicked the ADD VIDEO button and imported an MPEG-2 file with AC-3 audio;
10. I right mouse clicked on the file and then clicked MEDIA CLIP PROPERTIES to observe the following properties of this file:
FILE FORMAT: NTSC DVD
FILE SIZE: 27,542 KB
DURATION: 26.94 seconds
VIDEO TYPE: MPEG-2 Video, Field A
TOTAL FRAMES: 806 Frames
ATTRIBUTES: 24 Bits, 720 x 480
FRAME RATE: 29.97
DATA RATE: 8000KBPS
AUDIO TYPE: DOLBY DIGITAL AUDIO
TOTAL SAMPLES: 1,290,891 Samples
ATTRIBUTES: 48,000hz
BIT RATE: 256kbps
11. I clicked the NEXT button and configured the menu;
12. I clicked the NEXT button and I watched the preview; the sound was not audible (normal with AC-3);
13. I clicked the NEXT button and checked the RECORD TO DISC box;
14. I then clicked the OUTPUT icon and the burning process initiated and completed;
15. To test that the AC-3 audio had been passed through to the disc successfully - IN SPITE OF THE LACK OF OFFICIAL AC-3 SUPPORT - I then selected Ulead VideoStudio 7's DVD-VR capture plug-in and browsed to the Video_TS folder on the burned disc;
16. The burned MPEG file then appeared and it VERIFIED that the file's audio was AC-3 DOLBY DIGITAL.
Those who claim they are unable to burn AC-3 audio MPEGs successfully using VideoStudio and DVD MovieFactory fail because either...
a. they did not have their project settings set correctly;
b. they did not check the DO NOT CONVERT COMPLIANT MPEG FILES box;
c. they attempted to author the file from the VIDEOSTUDIO TIMELINE (a method that will *not* pass the AC-3 audio through successfully);
d. they first EDITED the MPEG.
Any of the above four conditions will result in failure to pass the AC-3 audio through successfully.
If one wishes to *edit* MPEGs with AC-3 audio, then it would be necessary to purchase an application that officially supports AC-3 encoding - such as Ulead MediaStudio Pro 7:
http://www.ulead.com/msp/runme.htm
or Ulead DVD Workshop AC-3:
http://www.ulead.com/dws/ac3.htm
Jerry Jones
http://www.jonesgroup.net -
Originally Posted by Anthony2k3
One post is enough.
https://www.videohelp.com/forum/viewtopic.php?t=174091&highlight=
And please don't hijack topics.
/Baldrick -
Nerovision Express 2 allows you to encode using Dolby AC-3 but I don't know if it will accept files that are already made without transcoding them itself.
Howard -
Vs7 will render AC3. From the review section of VS7 https://www.videohelp.com/tools.php?tool=79
This came packaged with Ulead Movie Factory 2 with my Pioneer A06 DVD burner. I've historically hated Ulead's products dating back to Video Studio 3 and 4, but i have found one very worthwhile use for this program. (In the bundle, at least) it can encode 100% compliant AC-3 (Dolby Digital) 2.0 audio. It didn't do this originally, but entering the lines:
PlayAC3=1
DecodeAC3=1
UleadAC3Encode=1
ADVANCE=1
into, well, basically any section of the *.ini files that come with the program, especially the [MPEGVIO] and [VIODriver] sections of UVS.ini and DVDMF.ini . this will enable advanced settings in the SE version under the MPEG-2 template options, making this an almost usable program. -
full versions of TMPGE DVD Author with Ac-3 plugin works great so does full verison of MovieFactory 3, both will accept AC-3 2.0 or 5.1 but both will only record in AC-3 2.0, no 5.1... yet. DVD author is the better of the 2 for editing while MF3 has more features for authoring, both programs cost about the same $100. Their trial version has the AC-3 stripped out of them. Dolby Digital is the one collecting the fee for the use of their AC-3.
Originally Posted by thxkid
It will accept AC-3 audio but if you want to use it to encode WAV or MP2 to AC-3 then you need the AC-3 plug-in so that would be why encoding is not supported with the demo version.
But even the demo version (or the full version without the AC-3 plug-in) will still accept AC-3 audio that you have created elsewhere for import.
Plus you can do some basic editing with it which seems to work rather well and that is a trick ... editing MPEG-2 with AC-3 and NOT doing any re-encoding ala TMPGEnc DVD Author.
TMPGEnc Authoring Works 4 (AC3 Plugin)
By likwid8 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2010, 03:30 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Winamp Won't Play 5.1 AC3
By DarrellS in forum AudioReplies: 2Last Post: 14th Mar 2009, 18:24 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 09:11 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 16:53
