I have a problem converting MPEG-1/MPEG-2/AVI to VCD or SVCD using TMPGEnc.
Although hardly notisable, there is a little jumpiness in the encoded file compared to the original. This problem seems to happen only with video files captured using my ATI AIW 7500 card. The results are the same with any resolution, with/without inverse telecine and motion search precision.
Is it any way to solve the problem ?
Thank you all in advance.
If you mean frames/second, I thought that the result, in order to be ready for burning, should be 29.976 f/s (VCD for example). How else I would burn the file on VCD/SVCD if it has different framerate ?
Also I actually capture with 29.976 f/s, so framerate should be the same. -
I do mean frames per second (FPS)
If your source and target are the same though, this is probably not the problem.
Just FYI: you can have different target/source framerates - e.g. encoding a PAL (25fps) source to a NTSC (29fps) or NTSC film (23.976fps) format.
The reason I asked was that TMPGEnc will let you do it, but it often causes problems like the one you're talking about.
Good luck finding the answer - sorry I couldn't be of more help.
cheers,
mcdruid.
Problem with Converting Directory of Files with Popcorn AudioConverter
By Petes457 in forum AudioReplies: 2Last Post: 28th Jun 2011, 15:25 -
Problem with converting MOV files from iMovie / Camera
By pred02 in forum Video ConversionReplies: 1Last Post: 23rd Sep 2009, 02:25 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
Converting video files to .AMV format problem.....
By TheGMan in forum Video ConversionReplies: 2Last Post: 26th Dec 2007, 02:45 -
Problem when converting DV AVI files to MPEG
By MI6 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 14:34
