Hi, I'm trying to make 3 mpegs into dvd compliant files with SVCD2DVDMPG v1.1. In the log it gets to step four and just stays there.
I chose mpg to ps in settings. In my working directory I get .m1v, .mpa, and .mp2 files. Is there something else that needs to happen?
I'll try to help you but i need the folling information:
1. you give use the version of svcddvdmpg+ you're using 1.1 isn't enough
2. the log so we can see al the steps.
3. information about your input file:
- audio sample rate
- file size
Greatings,
Yf -
I am not using svcd2mpg+, just the free version. I figured out my step 4 problem. I now get a new mpg with DVD in the name for each mpg. Is this correct? Is there anyway to output one large mpg joined already?
The output of the non plus version is an _DVD.mpg file for each file you put in. This file is a bit bigger then the input file cause the audio is a little bigger then the input.
If you still have trouble please put the information (2&3) in your next message
Greatings,
Yf
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 15:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 20:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 10:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 08:04 -
Good software to tag image and video streams that doesnt edit the headers?
By gfxcat in forum ComputerReplies: 0Last Post: 22nd Apr 2008, 13:47
