I have been ripping DVDs for a long time. I use Sefy's classic guide and have always ended up with excellent VCDs.
I came across KVCD sometime back and wanted to try it out.
My procedure was
Ripping VOBs - SmartRipper
FrameServing - DVD2AVI (save as .d2v and .wav files)
Encode - TMPGEnc (using the .d2v and wave files)
Authoring and Burning - VCDEasy (chapters from ChapterXtractor)
I did everything in the Sefy's guide except used KVCD templates while encoding using TMPEnc (which is the best ever I guess).
But the KVCD that comes out, no doubt is very good in video quality, has some kind of breaks in audio every few seconds.
Any comments/suggestions ????
on dvd player or PC??Originally Posted by zorrinn
keep in mind kVCD is a non-standard, compliant xVCD
you need to make sure your dvd player supports xVCDs and at what bitrate: https://www.videohelp.com/dvdplayers -
Hoave your tried going to www.kvcd.net and asking the same question. I now Kwag or someone there will be able to assist.
Bud -
Then it is possible something went wrong with encoding, or, you may have a bad MPEG codec on the PC, and also, your DVD might not support that type of format
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How can I rip DVD to AVI and make each chapter a seperate file
By mikeyshine in forum DVD RippingReplies: 10Last Post: 23rd Sep 2011, 15:02 -
How to make the best quality TV RIP in Avisynth-Megui?????HELP please
By rijubrata in forum Video ConversionReplies: 10Last Post: 5th Feb 2011, 05:26 -
DVD is only available from Australia (PAL)- can I rip it and make a copy?
By stoker in forum MacReplies: 6Last Post: 23rd Sep 2010, 00:11 -
How to make a lossless rip?
By Poro in forum Blu-ray RippingReplies: 5Last Post: 18th Sep 2010, 17:25 -
DVD to CD: how do I rip DVD to make a CD?
By ministerdavis in forum Newbie / General discussionsReplies: 4Last Post: 6th Jan 2009, 15:02
