When I load some particular avis, there is no audio.
If I use AVI2WAV, extract the audio, and load it manually... I get sync problems?
Probably because when I rip the audio it comes out 1 second longer???
Is there anyway to ake tmpg read the audio in the first place?
If you get audio errors, out of sync problems or bad audio or no audio at all, try to convert the audio to wav before converting.Hello.
hmmm
I see what you are saying..
But that didnt answer my question, I already convert the avi to wav.
If I go to the advanced settings/source range, the audio file doesnt load if it is an avi, only after I have converted it to a wav.
So the problem for me must be in the conversion from the avi to wav
Perhaps I should post in that section.
FOL furious with McAfree ap that auto loads with either Flash, Java or..
By edDV in forum Newbie / General discussionsReplies: 0Last Post: 6th Sep 2011, 23:02 -
Firefox only loads google
By Squid_uk in forum ComputerReplies: 11Last Post: 5th Aug 2010, 15:51 -
Player which Automatically Loads SRT
By aphirst in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2008, 17:17 -
no video_ts just loads of rar files, what do i do?
By andrew101 in forum Video ConversionReplies: 8Last Post: 10th Nov 2007, 23:44 -
Loads of problems converting avi etc. to dvd please help!!
By mrd2007 in forum Video ConversionReplies: 9Last Post: 14th Jul 2007, 12:53
