I seem to have successfully imaged to my G4 a DVD (of TV programming) that was burned in my Philips DVDR75. I used DVD_Imager and then Apple's Disk Copy. The problem is that while the resulting DVD will play on the Mac and in my Pioneer DVD player, it won't play in three others I tried it in: the Philips, a Sony or a portable Toshiba... even though all are supposed to play DVD-R disks, and have worked with other disks.
On the Sony, I get a "disk is dirty" message. On the others, nothing.
I know there is discussion of how funky the Philips burns disks, but it would seem that if the disk plays in some places, it should play in others. I even tried two different brands of blank disks (TDK and Memorex).
Am I missing something? Any suggestions? Thanks much.
http://www.avsforum.com/avs-vb/forumdisplay.php?s=&forumid=106
try looking or asking at the above, you might more infopants on, pants off, pants the floor. -
Go figure. I successfully burned another copy of this material, using Toast disk imaging. It plays in ALL the DVD players I mentioned before -- except the Pioneer! It would be really nice to find a way to make one disk that will work in all the players, but perhaps that is asking too much.
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21 -
format of subs which works on dvd players
By evile1690 in forum SubtitleReplies: 5Last Post: 4th May 2008, 09:46 -
Problem creating a dvd that works on standalone players from .avi xvid file
By brycej817 in forum Authoring (DVD)Replies: 4Last Post: 17th Apr 2008, 17:50 -
My DVD works in 95% of players!
By Bansaw in forum Authoring (DVD)Replies: 10Last Post: 4th Jul 2007, 11:16
